Selectively enables SNMP access on virtual routers.
| vr_name | Specifies the virtual router name. |
| all | Specifies all virtual routers. |
Enabled on all virtual routers.
Use this command to enable SNMP access on any or all virtual routers.
To disable SNMP access on virtual routers, use the disable snmp access vr command.
To display the SNMP configuration and statistics on a specified virtual router, use the show snmp vr_name command.
The following command enables SNMP access on the virtual router vr-finance:
enable snmp access vr vr-finance
This command was first available in ExtremeXOS 12.4.2.
